Software update ( firmware)
Thomas76
Has anyone got the link that I can download the new update firmware for my stereo please?here’s what is on mine at the moment.
I have sent it to you, that is the direct link to the Toyota site, I have also sent you a download link from google drive
As i said you may be running Windows 10S - The S stands for secure and stops you downloading anything except what's in the Microsoft store - 10S only allows you to use Edge too - if it's Not Windows 10S look in your downloads folder
Many members have done the update..................
  • 4 months later...
What's your current firmware version ? With or without Go (NAV)
  • 11 months later...
Bob
Can you send it over to me as will - Currently on XE3809 on a touch 2 without NAV
thanks
Keith
Good evening. By any chance could someone please help me update my touch 2? Without nav. It’s currently running on Software version:XE3953
Model ID:13TXDAEU-CA02. I’m having issues with my bluetooth where it stops playing ( no sound but it goes for 1.30 then goes back to 0 ) and also takes a long time to load up contacts and recently called numbers?
This is your thread lol, 3953 is the latest and probably last update for the Touch2 - it's likely your phone  needs turning off and back on again or needs an update, iPhone bluetooth is very flaky - there was an older update that broke BT a few months ago
Hi, can I also get the upgrade?
software version:XE3896
No satnav
  • 4 months later...
Hi flash could i get the latest firmware for the Model ID:13TXDAEU-CA02 ?
  • 3 months later...
Bonjour à tous
je souhaiterais savoir si il est possible de mettre a jour toyota yaris 3 de ma fille 2016
elle souhaiterais avoir le carplay sachant qu il y'a une camera de recule mais pas de gps
version du logiciel: xe3896
Merci pour vos reponses
I have satnav
thanks!
I have also the same model.
Can you please send me the firmware?
Hi I have Yaris mk4 hybrid 2021 UK is there a way to update the software to latest one? See details
Model ID DCU 17TDT1EU-CA31
Software version:XE3809
I do not have NAV.
Thank you in advance.
Hello. Update for that version with NAV unit, software version XE3809?
Thanks in advance.
no real benefit to the update  if you have NAV, but to do the update you need to disconnect the nav module and swap the USB cable from the Nav to the DA, perform the update and switch it back when done
with the Nav you need to do the TLS update that you can download from the My T website from the estore FOC
Hi
Where can I download an update for my Yaris 2017 multimedia without NAV ? On https://www.toyota.com/firmware-updates/updates, I find only Yaris from 2018.
Do you known if there is other possibility than CARABC to get Carplay on this system ?
Thanks already,
Regards,
toyota.com is the North American site so you will not find anything relevant for any UK/EU models
the touch2 gen2 does not support AA/AC, there are add on devices - these are expensive
i will pm an update
