Oil leaking from injector?
Mazzz
Hi, I've got a 1999 Corolla 1.3 and there seems to be oil leaking from the first injector on the left - see photo. Also the square rubber of that injector doesn't sit properly in its recess, compared to the other 3. The engine oil level ok.
What's the fix for this problem?
That is not an injector it is a spark plug lead, of there is oil in the tube then the seal around the tube to cylinder head has failed, you will need to replace the rocker cover gasket and 4 x tube seals.
As for fitment either the oil is swelling the rubber or it the wrong lead for the car.
Yes, of course, it's a spark plug lead thanks for the correction and diagnosis.
