Connecting factory camera to android radio - 2012 yaris mk3
Mike_mt
Hi, i have recently upgraded the original toyota touch radio to an aftermarket android radio. I would like to be able to connect the factory reversing camera to the new radio. Anyone have any info on the pinouts or which wires i need to connect to please?
UK spec, 2012 yaris (mk3) t-spirit with touch radio (no nav)
thank you in advance 🙏🏻
1 hour ago, flash22 said:
You will need a camera retention cable OR you can wire it yourself but beware the factory camera runs at 6v (5.5-7.0v)
iirc the touch uses the 16 pin connector for the camera
https://connects2.com/Product/ProductItem/CAM-TY1-RT
Thanks 🙂
It looks like the black 16 pin plug which is not connected to the android radio. However that site shows a different 24pin connector for the 2012 Yaris which is weird.
This is the plug which looks like it corresponds to the one linked
If you read the documents the 24 and 28 pin are for later cars (yaris 2014 on aka touch2)
the early Auris also uses the 16 pin for the camera (touch)
Thank you very much mate. 🙏🏻
As viewed from the socket on the rear of the radio, or wire side of the plug - pin 6 is handbrake
Do i have to wire pin 6 to anything? Or ground it?
The hand brake wire comes from the hand brake, it tells the radio if its on or off
Moved to the Yaris club.
Hi, i got this cable and wired it in, however the radio does not switch to reverse camera. I connected the wires properly (video to reverse camera video input, red to camera 12v and black to ground).
The radio also has another wire to sense when reverse is engaged. Not sure which wire to connect to… but I tried to join to the camera 12v but it still does not turn on/switch to it.
The red typically gets wired to the reverse signal, have you also wired the reverse wire on the head unit ?
Pin 2 on the 28 pin should read 12V when in reverse (if wired)
It does not seem to have anything in pin 2
ok your new radio has the 12V for the camera you need a 12v reverse signal input to pin 13
you will need to find the reverse wire in the body loom - I would need to look that up if it's LHD car
It is a RHD car. 2012 yaris t-spirit
The reverse wire runs from the rear of the car on the drivers side (LHD) or passenger side (RHD) in the body loom up the firewall and into the fuse box, it does not go through the connectors behind the drivers (lhd) or Passenger (RHD) kick panel
the wire colour is red you can track it down using a wire piercing probe or tap it in the fuse box
Pin 19 on BA1 - Verify with a multimeter that you have 12V in reverse
View of the plug is from the front (Left)
View of the socket as are looking at it (Right)
  • 3 months later...
Hi
I have problem with my factory  camera reverse on android media radio when i put in reverse gear nothing happens i conect conectors all what i get and how must goes,can someone help me
Do you have a reverse wire connected to the radio, the factory camera requires 5-7v or 6v nom.
Do you have the wiring diagram for this radio
On 6/10/2021 at 1:33 PM, flash22 said:
I dont know what reverse wire is in  conector of car,when i conect Android radio,only not working parking cam when i put in reverse gear,diagram i dont have for this Android radio
I only have this from internet something
Pin 3 on the radio (brown wire) goes to pin 2 on the white 28 pin white connector, the 28 pin on the yaris does not have a reverse pin
you need to find a reverse signal wire (12V when in reverse) - on a LHD it's in the main body loom on the driver's side it runs up behind the kick panel then up into the engine bay
See my post above
Aha so what i must do pin from conector of radio brown conect where?
So in this car conector brown pin not going in there?i must conect somewhere else ? Or?
I was thinking maybe this wire is reverse, and brown wire goes here, but nothing happens when i conect here
The brown wire comes from the radio to that socket but has no connection to the car - there is NO reverse wired
You need to wire the Brown to a Reverse signal
