Connecting factory camera to android radio - 2012 yaris mk3
Mike_mt
And this screen shot what i edit, conector is this and where i can find this?
See this diagram, connector BA1 inside the fuse box Pin 19 (red wire)
1523321960_gen3lhdengloomBA1.jpg.b0733b7
So there no wire for reverse,all this wires are not for reverse gear?
So here i must find red wire and then what conect new wire or what ? Sorry for my english
yes, red wire runs through car to reverse light - it is 12v when the car is in reverse
Ok and this pin 19 conect to new wire and conect to brown pin in white conector from radio ?
So i go now to car,see is this where is reverse wire,in this conector?
And here this ,see is this where is reverse ,where must brown wire go ? And how i do that
Find pin 19 on that plug from the diagram, give me time and i will post a pic
you shouldn't need that adapter as it's built in to that radio
Aha so i dont need this conector ok,so how i must conect that brown wire pin from conector to this reverse wire,i need new wire buy and how wire must be and how all that conect to work ?
Pin 19 should be a red wire, you will need to connect the brown wire to the reverse wire
So i must see where this red wires go or? How i conect this brown wire to this red wire what is on fuse box?
And is voltage be ok on wires ?and how this brown wire must conect to red wire reverse ?
How this must be conected ,new wire on brown and how must be conected on that reverse red wire 19?
Because i dont have one to do this,only to toyota service take this
Yesterday i conect wire brown to reverse red wire new aftermarket cam works,but factory cam when i conect not working black screen and lines for parking show,is there maybe in this conector problem in some wires
The black 16 pin is for the camera on your car, where does this connect to on your new radio ??
edit. looked at the pictures on the first page
you have 2 yellow camera plugs, swap them over
Is this ok i replace position in this konektor from radio then this goes to 16pin black conector from car
