Proace recall
Ped78
Has anybody seen a recall on Proace 2016-2019 models?
Something to do with "premature wear on the timing belt"
Just wondered whether anybody has any experience of this recall and what is required to rectify the issue?
  • 7 months later...
I've just had the water pump on my 2018 model replaced under warranty (according tge the AA guy who recovered me its a known fault). Was advised to replace timing belt by garage as they'd be removing it to change pump. Not sure if this is relevant to premature wear or just good advice.
Probably good advice as if it was being removed anyway, it delays having to have the belt replaced later on.
  • 1 year later...
Was the water pump included under warranty also as both timing belt and water pump go hand in hand!
