Passenger electric window not working
Debell
I have a 14 plate ago the passenger window has suddenly stopped working. I tried the drivers side switch on the passenger side and it worked.  Am confused as what and how to test next, any ideas please
pop the switch apart, it may just be a bit of crud in the contacts
Its common for the regulator or motor to play up, this puts higher current through the switch and burns it out so you may end up with the same issue
As flash22 says, probably oxidized contacts or crud due to lack of use. Before you take it apart, try operating the switch a few dozen times with the ignition off. Then give it a go with the ignition on. If no joy, then take apart like flash22 mentions.
