2009 Aygo driver's mat retaining pin
Reddaddy67
Hi, the retaining pin for the driver's floor mat has pulled out of it's fixture in the carpet.
Question is how do I secure this back to the small carpet hole it came from? This is just the lower portion which needs fixing securely.
Many thanks👍👍
There's no screw thread on this at all, there appears to be just a hole in the carpet where this base piece has come from, the top portion just pops into this and is currently still in the mat, I just removed this for the photo as it's the bit I need to secure but as it appears to only adhere to the carpet it seems slightly odd as there's no actual fixing point 🥺
I had the same problem the other day ..button came off with the mat ! With a bit of patients and a couple of screwdrivers I prised the two bits apart .
            Then I lifted up the carpet…super glued the bit that going  underneath…then press the top part on..again bit of super glue, now like new .
      As you say it’s not a screw thread the top part, the little claws that lock it together need to be teased apart…very fiddly but it can be done 👍🏻👍🏻
