press starter button and just gets clicking sound
g brett
starter just clicking not turning over engine
Your starter might have gone bad or your key is low on Battery
Any history of problems recently…. No matter what?
8 minutes ago, Ikram Shahar said:
Your starter might have gone bad or your key is low on battery
thanks will try new key Battery as had a new starter
7 hours ago, g brett said:
thanks will try new key battery as had a new starter
Its not a key Battery as if it were the car would not try and crank, the noise you hear is the starter solenoid bouncing back and forward this is caused by a low 12v car Battery which does not have enough power to engage and hold the solenoid in place whilst the car cranks
If it’s the original 12v Battery, it’s 6 years old so in the time period for replacement.
