Passenger Wing Mirror Flashing Rapid
SAM LOVERS HER TOYOTAS
Hi Guys,
Noticed today that the passenger side wing mirror led indicator is flashing rapidly on our 2010 T27 Diesel saloon.
Does anybody know why this is?
Is it one of those on board diagnostic signs that another bulb else where has blown? Or is it something more serious?
Please help. Im hoping its not that particular led unit on the mirror because they don't come cheap sadly
Cheers
SAMMY
You have a blown bulb on the passenger side, either front or rear
  • Like 4
Cheers flash22, ill be sure to check front and rear, could it be any bulb, even a headlight bulb or a side light bulb thats dead?
It will be either the front or rear indicator bulb on that side that has failed / requires replacing.
Switch the indicator on for that side & you will soon find which of the indicator bulbs has blown.
Cheers, much appreciated, Halfords here i come, wonder if those bulbs are off set?
Culprit found...rear passenger! Forgot we'd installed chrome bulbs, hmm, might have to go back to that fried orange look for now.
Problem solved..that has to be my fastest fix in a decade!
Cheers flash22 and forkingabout! Much appreciated
  • Like 3
Cheers flash22 and forkingabout! Much appreciated problem.
now look to see if your Handbook says anything about your problem SAM
Doubt it very much if it says anything at all!
