Toyota Yaris Ecovan
FROSTYBALLS
Currently only offered in Spain, the Yaris Ecovan follows in the footsteps of other van versions of the Aygo, Yaris and Auris. Unlikely to be offered in the UK
https://www.carscoops.com/2021/08/toyota-yaris-ecovan-is-a-two-seater-supermini-with-hybrid-powertrain-plenty-of-cargo-space/
Awww I was expecting something like the old Yaris Verso but it's literally just a Mk4 with the rear seats removed! You even loose the footwell space!
No different to previous versions:
See the source image
the Auris has/had the N1 Conversion
The Gen 4 also has the van conversion - Your bog-standard, Car derived Van - The Astra van is just an Astra estate with some side panels you could fit a rear seat and belts and have a 5 seater
https://www.toyota-tech.eu/aimuploads/6cb1c398-93c2-4034-bbf7-5de1b69bbd53/Yaris_N1_HV_PW710_0D005_AIM_006_038_2.pdf
and the divider
https://www.toyota-tech.eu/aimuploads/83c2f2cc-b1b0-4b74-aa9d-c2b4ca0212e5/Yaris_Full_Top_Separator_PW710_0D004_AIM_006_111_0.pdf
