Fuel gauge odometer tripmeter
My 2003 Yaris Tsport has a small problem.
The tiny binnacle within the main instrument binnacle has stopped lighting up when the ignition is turned on.
The instruments still work , they can be seen (just) when it's dark.
I realise that it's a long shot , but has anyone had the same problem and managed to replace the bulb ? Or maybe it is LED lit .
I can't see a way of removing the main binnacle to have a look.
Thank you flash, that is very helpful indeed.
I can only apologise that I did not think of searching YouTube myself.😞
And the parts link too , you certainly know how to find things , much appreciated.
Not sure if you access the bulbs from the rear or the front, there are only a few manuals around for the mk1 and most of them are missing lots of info
I'm sure you can figure it out
Yes I think I can sort it with that information thanks , still amazed and delighted that this is the only problem ,(apart from the inner cills needing a wire brush and waxoyl)in what will be 2 years of ownership come September.
