OBDII: CAT_RDY INC and O2S_RDY INC
Biomecanoid
Hello,
I have a 2006 Daihatsu Sirion  ( Same car as Toyota Passo ) I have for about 3-4 months now a CAT_RDY INC under I/M Readiness. NO errors codes or check engine light.
Today I realized on top of that I have a O2S_RDY INC.
Car is running fine good acceleration, good top speed. Only thing I have noticed is a bit higher fuel consumption.
The only thing that I did today is take the car for the yearly oil change and since its weekend and I have some free time I did some checks on the car: Fluids, Battery, Tyre pressure etc and when I connected the OBDII I found I have one more I/M Readiness INC.
When I took the car to the mechanic for the oil change I told him I have a CAT_RDY INC and without looking at the car he told that the O2 sensor need replacing. After I took the car back from the mechanic the O2S_RDY INC popper up in OBDII. Coincidence ?
What needs to be done now ? Replace the CAT and O2 sensor ? thats like 1000£ job and recommendations ?
Inc = incomplete
what is your coolant temp ? what are your MAF/Map readings (g/s)
I have no temp readings on the dash, but I will post all the other readings from the OBDII
Temperature is a standard obd2 information, the ecu requires a temperature to calculate the fueling
This is all the readings from the OBDII after a slow 20min drive
The 02 sensors are in spec the engine thinks it is lean so is over fuelling, it's likely a vacuum leak
what engine do you have ? What is the mileage ?
The engine is the 1KR-FE 1000cc 61000 miles the same engine with Toyota Yaris and Toyota Passo
4 hours ago, flash22 said:
It could just be a bad injector dumping fuel
Yes I was told that too. So what should i check so far ?
*Vaccum Leak
*Injectors
what else ?
Pick one and trace it down - if it's ok move on to the next possible cause
So only 2 things to check , Injectors and Vaccum Leaks ?
Actually I have changed spark plugs on November 2019 but I have never changed the injectors in the 4 years I have the car. So sounds plausible
What actions should I take ? Check for vacuum leaks and for leaky injectors ? only those 2 things ?
