Squeak / Squeal from engine bay area of a 2009 plate
Steve2022
Hi, I have a 2009 plate Aygo and at certain revs or going over a bump I get a squeak / squeal front the front.
I noticed today with the bonnet up while it was idling while it was doing it if I pressed down with a little force of the airbox it would stop.
Is it possible for an engine mount to squeak / squeal?
It sounds like a light belt squeal noise but obviously can't be a belt if it stops when I press on the airbox...
are the rubber hoses that connect to the throttle body still tight /undamaged
Will take a look but it's hammering it down right now lol.
At first I thought it was the springs holding the exhaust onto the cat/downpipe but they seem nice and tight and surely pressing down on the engine wouldn't stop them squeaking?
1 hour ago, Vandals01 said:
It could be anything.  Personally, I think this is worth a try:
https://www.amazon.co.uk/NEILSEN-TOOLS-Mechanics-Stethoscope-Traditional/dp/B005S0E23S/
Just tap around the engine until you can isolate the noise.
You can do that with a long screwdriver pressed to your ear.
