2017 Toyota RAV4 Honking
Robertbhop
My Rav4 is going crazy.  It honks ten times when I go to get in it and sometimes it honks 3-5 times.  It has been in the past month and sometimes it will not lock or unlock.  I had to get my valet key to open the door a few times and it just honks...  Help me
The key-fob is new but I guess the Battery could be old.  I will replace it and let you know.  Thank you
Is the car starting ok ?
It starts fine and the new Keyfob apparently had an old Battery.  It has been okay since I replaced the Battery but  I also turned the security system off and have had no more honking.
Hello
Check the Battery terminals for looseness or corrosion build up on round bits/further down and Battery negative to body connection.
Can also check/clean horn grounding. They are located between front bumper and radiator. There's 2 of them.
Hope this helps.
