Rubbing noise when AC is off
Mark16
My 2016 Avensis makes a rubbing noise when I turn off AC. Once I turn AC on it stops?
Noisy AC pulley bearing - its the  bearing that allows the compressor pulley to spin freely when the compressor clutch is not engaged. The bearing locks along with the pulley when the compressor clutch is engaged.  You should be able to replace the clutch/pulley assembly.
