RAV4 injector problem
Liam83
Short circuit/open circuit injector no 3
would it be injector or wiring fault . I replaced all four injectors last year
solenoid (wiring) issue of course
injection is controlled by a sygnal from solenoin
cheers \ Igor
  • 9 months later...
Hi Liam83
Did you ever get to the bottom of your issue, I'm having the same fault, shows check awd, check engine light come on, read the fault code and it shows injector 3 open.
I have a 2013 rav4 2.2 auto dcat
