Toyota Estima hybrid problem
HKSK
Hi Everyone .
I’m a newbie to these forums, I’ve got a Toyota Hybrid 2.4 Estima X 4WD never had any problem
But recently when I start the car the ABS light, coolant light, P/S Light, Brake Light stays on or should i say the whole dashboard, electric door doesn't work and the speedometer just moves up and down with no real speed when i drive and but it drives with no problem apart from this
And Sometimes when the car is stationed the electric door doesn’t work .
and at last
 But in a few occasions my car went on a small pothole and the car made a Click sound and all the lights went off and the speedometer back to normal,but when I turn  off the car and on again the problem came back again
Can anyone give me some idea before I get it to the garage.
Thank you very much in advance
Moved to the Estima forum
Get the codes read (if any), it's potentially a combination meter issue (gauges)
U01 codes is a network (canbus) error
its either the gauges or hvac controls/AC amplifier
I would start by unplugging the hvac controls and see if the gauges come back
edit. 2007 is a changeover year, do you have the half round heater controls or the one with the gear selector in the dash ?
  • 1 year later...
Did you fix the problems. I have the same error code and blinking dashboard lights.
