Bolt size
Joby
Hi there,can anyone help me to find out size(diameter) of verso 2007 model wheel nut,16 inch wheel
Thank you
Moved to the Corolla club (the Verso S is a different model to the Corolla Verso).
I don't have a Corolla Verso, but, does your wheel nut look like this one?
If it does, were you looking for the maximum width (arrowed), or some other dimension?
Across that washer shown, which is built-in, it is 30 mm in diameter.
Ah, I see!
Your car has steel wheels with wheel trims.
From your photograph, I'd say the wheel nuts were different to the one I showed (which is the normal fitment for Toyotas with alloy wheels).
1 hour ago, Gerg said:
Ah, I see!
alloys & steels generally use different wheel nuts with different seats.
