Aygo AvMap module plug one (left) 6 pin molex connector wiring layout.
MohMal
I've encountered a problem whilst wiring a retro fit full X-Nav kit to our 2018 Aygo. The AvMap module (glovebox area top left). This has 3 plug in's. The left connector is a 6 pin molex, the centre is a 90 degree turn USB cable, the third is a 4 pin molex connector. During fitting I've pulled the 6 pins wires out accidentally (Idiot I am yanking the cable whilst holding the plug connector), now I have no idea which wire goes to which PIN no. I wonder if someone else has had this problem or if anyone can try gaining access to there AvMap unit and take a picture of the 6 pin molex connector wire feed end, so I'm able to re-position my wire colours correctly. There is a blue, green, purple top row and two black on bottom, with a blank pin Any help or advice would be appreciated.
