Air vents
Stormchaser
My wife has a 2020 X Trend.We have one thing with the air vents inside that annoys us.The centre vent (photo included) is always blowing air in your face regardless of how we position the direction on the control panel,it just won,t stop even with no fan on.Is there any way we can stop this?
Next stage would be sticking tape over to stop it but would look bad.
AFAIK that's where the fan that cools the radio/infotainment system blows out, it's not part of the heating /AC system.
You must have very wide heads if air is blowing in your face !
As the infotainment system is prone to misbehaving when it gets hot, restricting that vent would not be a good idea.
Constructive reply thanks for the input.
I have the seat far back as i,m 6`4" tall and this vent has a wide air flow.
I'm a mere 5' 11" but I can't say I've noticed the air coming out this vent even though I have definitely heard the radio cooling fan running - you must have very sensitive skin?
  • Haha 1
It's the centre heater vent, and it connected to the main duct - constant flow means you have the recirc set to fresh air
the centre vent will be the path of least resistance
pic for reference
https://www.megazip.net/zapchasti-dlya-avtomobilej/toyota/aygo-38483/kgb40-56115/kgb40r-agmgkw-919810/heating-air-conditioning-control-air-duct-17856862?nid=10333226#g17856862/heating-amp-air-conditioning-control-amp-air-duct/il-413570439-10333226-10333226
manual A/C or Climate ?
https://d24bc9lyrt5en5.cloudfront.net/Customer-Portal-Admin/emanuals/TOYOTA/OM99U33E.pdf
TBH it's just a case of setting up the airflow mode (mode 4 - feet and screen)
If you still have an issue, take it to the dealers as it may have a blend door / motor problem
  • 6 months later...
is there a way to make the center vent blow to ur face when you put cooler fan on. since it puts are upwards and not towards the person .
no, a frayed knot,
unless you want to mock up a deflector/hood
