Dash cam
Mr stevens
Hi, fitting a dash cam with a next base hardwire kit not but sure which is the best fuse to use in fuse box for a switch live any advice would be appreciated
thanks ??
I used the Power Outlet fuse. That way you are tapping into a circuit already earmarked for “accessories”. It’s also easy to identify being at the end of the box.
