X-touch not switching to reverse camera
GunbleR
Hello.
Got Citroen c1 2017(aka toyota aygo) with 86140-0h010 x-touch toyota multimedia. After replacing Battery, x-touch system no longer switching to reverse camera.
Checked the reverse pin in connector, and it does recieve 12v on reverse, under-dash fuses are good and reverse light is working. I believe the camera is stock, but cant be sure.
Any ideas what can cause/solve this problem?
Do you get a black screen or nothing ? Check the camera is getting its 6 volts in reverse
Nothing changed on screen, i could operate it normally. Tried to find soft toggle for camera in HU, did not found
You can do a camera and reverse check in the hidden menu
Press and hold the lower button (physical button) and turn the lights on and off 3 times (or until the menu comes up)
I have similar problem with my aygo its not switching to camera , want to measure the reverse signal 12v but which pin to test?
As above, run the test in the hidden service menu  iirc its under function tests on page 2 (top right)
Finally got to this friend's car. In hidden menu, Vehicle signal does register reverse gear, but no second page in function check.
I will try to measure 6v and splice rca to see image on external tv
Edit.
I do get 6v out on hu and camera shows on external tv. I'm thinking about upgrading firmware to HU manually. Any suggestions?
Edited by GunbleR
On 1/9/2022 at 5:01 AM, vol said:
1615184260_Screenshot_20220214-192838_AdobeAcrobat.thumb.jpg.adf17ddb28aca60ed23bcb79b181641e.jpg
If i remember correctly, it means "look from the back", so it may be pin #2
Also, i had reverse indication on black wire(originally -6v according to aftermarket adapters) in camera connector, when it was disconnected from HU.
when connected to hu, hu forced 0v onto it
click on "Vehicle Signal" in that hidden menu, the HU may not be getting a reverse signal or correct waveform from the camera
The camera looks to have moisture ingress (common) - replace the camera
