USB charge port
Pedal Head
4 hours ago, Pedal Head said:
Anyone any experiece with this or anything similar? seems it would fit. Looking to add a charge port to blanked off switch to the drivers right side.
https://www.ebay.co.uk/itm/393649616844?var=662390063804
i bought this one and plugged it into my cig lighter plug handy enough had great reviews also thats why i bought it
(Anker Car Charger, Mini 24W Dual USB Car Charger, PowerDrive 2 Alloy Car Adapter with Blue LED for iPhone12/12 Pro/11/11 Pro/XR/Xs/Max/X, iPad Pro/Air 2/mini, Galaxy (Not Compatible with Quick Charge)
 https://uk.anker.com/products/a2727
a mate of mine fitted something similar to his corolla, i know he wired it back to the fuse box, a proper job!  hardest part is say is fishing the wires?
They all should fit!
When I got my first USB adapter for my T27, I got a AUX/USB socket port and first installed it in the blanking plate left of the steering wheel above the parking brake switch.
tutorials-76861-0-67181900-1443253171_th tutorials-76861-0-09643400-1443253190_th tutorials-76861-0-71095000-1443087509_th tutorials-76861-0-00319900-1442736166_th tutorials-76861-0-55360300-1443087292_th tutorials-76861-0-38160800-1443260352_th
I moved the socket to the centre console, because I was aware that I could accidently hit the protruding USB memory stick, whilst reaching for the parking brake switch - my car is the early release off/manual engage parking brake. It replaced the AUX only socket and it works like factory with the Bluetooth/USB adapter.
You might also consider a right angle or adjustable USB adapter to avoid the stick sticking out.
Thanks for the link. I'm planning on putting to the right of the steering wheel as means to power/charge a phone so only need a feed.
