Wheel and tyre recommends for a track day
Big martin
Hi, has anyone completed a track day in their Celica tsport?
Any advice on wheel or tyre combos?
Car currently on 205/45/17 Avon ZV7.
Is there anything else that I need to consider as preparation for the day?
Thanks for any advice 👍
Unlike the VVTi, the VVTi-L in the TS does not have a baffled sump.
Strongly recommend you replace the 5W30 with 5W40 while on track to avoid a big repair bill.
The cheapest way to better performance is to shed weight.
If money is no object, a set of 16" light-weight rims, such as Pro Race 1.2 would make a huge difference, as the torque on these cars is puny.
Also, ensure the calipers are working perfectly. The rears especially need regular maintenance (strip/clean/lubricate).
Thanks for the reply 👍
I have read about potential oil starvation and have now put a 40 rated oil in the sump and renewed the filter. It it worth overfilling slightly until I baffle the sump?
Re shedding weight I will remove rear seats, boot trims, spare wheel, jack etc. I’ve also joined the gym so will see how that goes🤣
Money is a bit tight atm so will run standard tyres for now (need to fix a front strut that’s burst as well now)😢
I have freed off and lubricated all caliper sliders, fitted new discs and pads all round with bigger Avensis calipers and discs to the front.
