choosing and fitting a aygo satnav
fernmo
Doesn't your multimedia unit have Apple Carplay and Android Auto? In which case you can use your mobile .....
In the other case , it would be useful to know what radio (multimedia) you have.
Is it the one with two fysical buttons ? Three buttons ? Or the greyish one with more buttons ?
There is an add on nav system for sale from Toyota. Been described here on the forum.
But IMHO , what Frostyballs says is right. if you have the three buttoned one : just use your smartphone.
That is the best, cheapest choice and you can choose from many different nav apps.
Give us more info and somebody will give you the right advice here.
@fernmo says he has a 2022 Aygo so unless it's been in dealer stock since early 2018 it should have the 3 button CarPlay and Android Auto compatible radio ... AND not be compatible with the older sat nav add-on you mention (and which has been discontinued).
Didn't know that one was discontinued.
Didn't the basic low cost models in soms countries get the old type radio with the grey buttons, no touch screen, still in 2022  ?
No idea about UK specs.
The base spec cars get the basic radio next step up is the X-touch, then X-nav*, The Triple play being at the top (YV020. YV010) if the OP has a 2022 why not order the car with the features you wanted
X-nav was still an option on the x-play up to late 2019
https://www.toyota.co.uk/download/cms/gben/AYGO Prices Specification and Equipment Jan 19_tcm-3060-1574888.pdf
Build stopped in late 2021, maybe OP bought from stock so couldn't specify build options?
