Ventilation and Damper Sub Serv Assembly
johnson2511
I have a 2018 Toyota Corolla.  My car will not defrost.  I can get my windshield partially defrosted but all other window go completely fogged. Dealer says I need a new Damper sub server assembly.  What is this and what does it do?  Where is it located?  Thanks
Hi, you can search this side find your model and look diagram and cross reference numbers below , then you can use these numbers to search in Google for prices and stock availability worldwide. Good luck
 https://japancars.ru/index.php?route=catalog/toyota
