Cylinder head removal. 2.0 d4d
kevinf
attempting to remove the cylinder head and got as far as removing the injectors,
noted the strange looking banjo bolts on the fuel leak off rail, I thought that I needed to use a 6 mm Allen key to remove the banjo bolt, but only removed a blanking plug
will the banjo bolts screw out of the injectors as you would expect and if so what’s the blanking plugs for
thanks
