Electric mirrors for mk1 Aygo
Colin J.S
Hi All, can anyone advise whether electric mirrors from a mk2 would fit a mk1 ? I have seen a mk1 with electric mirrors on you tube but theres no text etc explaining how it was done.
I very much doubt it, not sure if the Aygo uses the same mirrors as another model - the mk1's mirrors are fully manual
Mk1 Mirror - 87910-0H021
Mk2 Mirror - 87910-0H061
The car in the vid doesn't look like a mk2 - Its not an Aygo
It's a Facelift mk1 going off the headlight and bumper insert, the mirror look odd, they are E marked repeaters tho
After another look around, they look like Toyota IQ aka Prius Mirrors
  • Thanks 2
It doesn't look like either a Mk1 or Mk2 Aygo - there are no side repeaters on the front wing.
The guy states it's a mk1 car. I have messaged him and await a response 🙂
looks like a mk1 to me , if he's into modding then maybe smoothed the side repeaters and uses the mirror ones
Thanks for your response. I have messaged the guy and await a response. I run a couple of FB pages for these cars and someone posted the video so I'm just very curious as to how it was done 🙂
Yeah, its deffo a mk1 and I'm trying to find out what the mirror came off, w will see if he replies to me 🙂
Me too, I'd live to have power folding mirrors on my Mk2 - it's a PITA having to manually fold them when using a car wash.
IQ, Jap Prius or mk3 yaris and swap the baseplates over
A few snipped close ups
Note the bevelled edge around the repeater
I'm chatting to the guy, he said it's IQ he used and awaiting more response but that's helpful, thank you......is the jap Prius different to uk Prius ?
Yes it's an IQ mirror
i have part numbers and wiring diagrams if required
Good find, always like to see something different, heard of heated mirrors on MK1 but not this.
22 minutes ago, flash22 said:
Yes it's an IQ mirror    i have part numbers and wiring diagrams if required
Are you able to tell me what year IQ ....I might be interested in getting some and wiring just the indicators, it would be way too much to get switches and wire the rest up
To wire the electric mirrors it's 10 wires, 2 for up/down, 2 for left/right, 2 for fold/unfold, 2 for the heated mirror and 2 for the repeater
the IQ was in production from 2008 to 2014
led side repeater, heated and folding (remote) from 11/09 - 05/12
RH - 87910-74040
LH - 87940-74040
12-14 cars had a bulb instead of an LED repeater
  • Thanks 2
Please share the wiring diagrams also, would like to do this on a Mk2 that already has heated electric mirrors so would just need to sort out the folding wiring and the mounting base swap.
Thanks.... I'd really appreciate the wiring diagram and also guidance as to the control module required. I guess the switches are all the same?
All the logic is in the mirror switch, no they are not all the same  most of the cars use the same switch gear tho - its 8 wires to the mirrors my mistake
Not sure if it can be done on the mk2 as the mirrors are different, that's something you will need to figure out
i did a thread on the yaris switch change
diagrams, you can use the IQ, Yaris or Auris ones i have all 3 types
the simplest diagram i have
Many thanks for this...I'll give you a shout if I get stuck 🙂
It's the 28 pin (3 row) mirror switch you are looking for pref with the connector but there are other folding switches
Those numbers are meaningless, they are related to the OE manufacturer - IF the L and R is bright white it's not backlit
Sounds like get a pair of the power folding mirrors and start experimenting...
The Mk2 mirror switch has a 2 row 24 pin connector 90980-12554, is there any power folding switch with that connector (if not it's connector change time too)?
Electric Mirrors.pdf
There are 5-6 types  9-10 pin single row, 16 pin (2row) with 9 or 11 pins on the lower row, 24 pin black sockets, iirc there is also a 24 pin blue plug
they should all use the same in type terminals iirc
edit. in your case unless you want remote folding mirrors just add a switch to fold them
Edit 1. https://www.iq-forums.com/threads/iq-jdm-power-folding-mirrors.2404/
Edit 2, i would buy a good used switch over an aftermarket part - 183575 or 84870-28020 non backlit, Not remote
