Sat Nav - Corolla HB/TS Touring Sport
carol47
Hi everyone, hope you can help me.
I have had my Corolla for a week now and want to know how to stop the sat nav coming on when I am not using it.  Everytime I go round a corner the sat nav comes on when I just want the screen for the radio.
Thank you Carol
The map is the home screen isn't it? It is in mine anyway.
Try this:
Setup -> General -> Auto change to screen - Off
Mr B is right the Home Screen comes on by default if you want the radio screen press audio then select your source ie FM DAB USB.
7 minutes ago, Extreme_One said:
Try this:
And that as well
thanks all     I'm not going out for a drive tonight so I'll see if it works tomorrow.
Carol
IT WORKS, thanks.  I found the sat nav coming on all the time very distracting
  • 4 weeks later...
Recently discovered this.
I have another problem with the Sat nav,would appreciate any advice.
Although I have set the Day/Night to Auto,the screen just stays on Day screen all the time,which is way to bright when driving  on unlit roads.
Currently I am having to leave it set on night screen,which is for less tiring on the eyes!!!
Try changing "light sensor sensitivity to +2" in automatic light control system. Might work, but to be honest I've not noticed any difference when I change it. Toyota needs to adjust the sensor to make a noticeable difference.
