Sat-Nav problem
clivecalpe
When I load a destination into my Yaris in-built sat-nav, it gives the title as "my address to another address" and only gives the first line of that address. I want to be able to change the title to (for example) "Crown Hotel London" or "My son's house", but the edit button only seems to give the option to delete the route. Does anyone know if this can be done. Giving just the first line of an address is meaningless especially with hotels and the like.
Thanks in advance, Clive
Is this when you load it via the MyT app (or MyT website) or if you put it in manually?
This is when I load it via the MyT app on my phone.
The MyT phone app won't let you add names to routes. If you send a route to the car via the MyT website you have the option to name the route. It will then show up on your unit as the name you gave it.
Thanks for that, I'll give it a try.
Cheers!
Let us know how you get on
Hi Bob,
Yes, problem solved. It took me a while to find where to input the info on the website but got there in there end.
Many thanks and much appreciated!
Clive
You're welcome. Glad you got there in the end.
