Engine oil
Zeddi
What are people using as engine oil as mine is at minimum I was thinking off draining it out and put fresh oil in also how much oil does the engine hold.
I was thinking 5w 30
What do you use as its a hybrid
Recent topic..the answer is on this forum.
Seems 0w 20 is the way to go for a hybrid.
See thread "correct engine oil"
Let me check, is that recommend regardless off mileage.
new to the forum struggling to use the app...
Toyota don't specify oils in relation to mileage.
For hybrids pre-2019 their recommendation is 0W-20 to either API SL, SM or SN.
