Brake power low
Meta
Were you holding down the brake pedal firmly enough when you started it? Might not have started it properly.
Also, a few people who have reported this found it was due to a dying 12v Battery - Apparently when the 12v battery's voltage gets low it causes all sorts of weird things to happen in the car!
If I remember correctly, the brake system runs off compressed air and has to pressurise before it will work.
This would possibly confirm a dying 12v Battery as the system wouldn't have the power to run the compressor to give enough pressure
