2012 estima tyre pressure
Eamonn22
Hi All, im not sure so would rather get some expert advice in here regarding tyre pressure for my estima, the wall tyre says 50PSI, they were at only 38 so i increased it to 42PSI all round, is this okay or should i have them at 50PSI please ? It just seems so high, photos wont upload, server error
Usually the pressure written on the tyre is the maximum pressure the tyre can handle, not the correct pressure for the car.  A quick google says they should be 33psi for an Estima, but perhaps google a bit more thoroughly for your particular car and size tyres.
The recommended pressure is usually listed in the manual, but also on the car on a sticker on the driver-side door or glovebox.
That's way too high.....My v6 is 32psi all round..and has been so for six years with no problems or undue tyre wear.
Thanks guys, ill check sticker on door or glovebox if not there ill google lens translate the manual and see if in it
Hi folks so this is what manual says but ive no idea what that is in PSI
250kPa is about 36 psi
420 is about 60 (!!)
Thanks appreciate It, ill lower them all to 36PSI so
