Yaris T sport instrument cluster
jncodan
Flash 22.... Is the amethyst trim color actually lavender/purple? I have never seen it iirc...
2000 vs 2004 electrical diagram. I ordered both of the dealer wiring books. The 04vs 03 books had the same publishing #, so I figured they were the same book
i did pm you all the required info and there are pinouts on the previous page of this thread
I printed it out and had a hard time reading it... I couldn't get a clear view. Even when I tried using my CSI/NCIS knowledge... No matter how much I yelled "Enhance" at my computer.
I have worked out the pin out changes from one to the other.
The tach cluster has two additional, one for the tachometer (I know where to get that signal) and one from the 'Headlight, LH, RH' which I believe controls the high beam indicator. no corresponding wire on the schematic that I can find.
The pinout map is dependent on the plug map.  The plugs are labeled as C13 (A) and C14 (B). The plug position numbers are based on the plug facing you, wiring side pointed away from you, plug release "button" pointing up. Plug A (C13) is smaller top row is A1-A9, bottom row is A10-A18 reading from left to right. Plug B (C14) same rules, larger plug top is B1-11 bottom is B12-22
plug pinout change map left is old (tachless) right is new (w/ tachometer)
19B-14A
Tach-15A
12A-1B
20B-13A
11A-8A
17B-9A
18B-12A
21B-16A
13A-14B
14A-2B
2B-17A
4A-10A
5B-19B
11B-16B
22B-17B
18A-18B
2A-2A (no pin change required!)
17A-12B
9B-5A
15A-20B
8A-8B
6A-4B
5A-3B
1B-18A
?From headlight LH, RH?- 22B             <High Beam Indicator>
16A-21B
6B-11B
3B-15B
7A-13B
12B-9B
13B-10B
4B-7B
14B-1A
This map is currently UNTESTED. Use at your own risk. I will be building my adapter harness soon to test this pinout change. I DO know where to get the necessary signal for the tachometer. I DO NOT know where to get the signal for 22B, which I believe is for the high beam indicator, and might be different due to the facelift vehicles having daytime running lamps as standard. Not sure about this. I dont know if I can just get a stalk and drl module out of a newer car and just plug them in and pull the necessary signal from the drl module.
Any input would be appreciated.
  • Haha 1
Be aware of the old drawings 2000-2002, connector A is 22 pin (C11) and B is 18 Pin (C12) your books have it the other way around
A1 (old) - A22 (new) 12v+ constant (doesn't have to be A1 just a constant 12v)
A4 (old) - A7 (new) negative (ground side switched)
or
B1 (old) - B22 (new) 12v+ constant
B4 (old) - B7 (new) negative (ground side switched)
Views - Oem are the socket views (wire side of the plug), some pin outs are shown as terminal view
I can sort something out tomorrow, iirc you are 7-8 hours behind us
Very nice pdf spreaheet , flash 22!
I am unsure why manuals I have ID the plugs differently... Both books, 2000 and 2004 ID c13 small as A and c14 large as B.
2000 pub. No. EWD395U
2004 pub. no. EWD542UPXL_20220430_191619932.thumb.jpg.5a9983399018aface8601207357df65c.jpgPXL_20220430_191601426.thumb.jpg.5d3c1fb2908c03cceb6d4b3c57eefc85.jpgPXL_20220430_193255484.thumb.jpg.61556811c7c46ee55f811e794778360b.jpgPXL_20220430_193331508.thumb.jpg.1883ea77b8f3e9cc0a6cb939083ac597.jpg
No problem, it didn't take long to put together, just sat here and listened to a video
