Aygo wheels
Biddly
Does anyone know if Aygo mk2 wheels will fit an Aygo mk1?
Should do, they're still 4x100 PCD AFAIK so they'll go on the hub at the very least, but there are 14 and 15 inch versions with different tyre widths and heights you'd need to check so it doesn't mess up the speedo
mk1 are all 14" 4x100 et 39 either 4.5 or 5J width, mk2 are 14" or 15" 4x100 et35 4.5J
