D4d fuel filter location
Scottie pippen
Hi, just tryn to get as much info as possible for fuel filter replacement and location on my previa 2lt d4d. Im not getting any returns in my forum searches, am i doing something wrong. Is there a “how to”, and i havnt found it. Thanks everyone.
  • 3 months later...
Assuming you have the 1CD-FTV engine in the Previa. The filter is in the engine compartment to the right of the engine  when viewed from the front. You can search for D4D fuel filter replacement. Even if it doesn't show the Previa specifically, it should give you enough to identify the filter housing and the process. From memory, it's a little messy and don't forget to prime (pump) the filter afterwards.
