speed camera ahead
fourbanks
I can't get this to work, despite the fact the box is ticked audio and visual. Any suggestions as to where I'm going wrong. Also, is it just for speed cameras? What about red light camera ahead, which I had in my Mazda
thanks
I believe you need to make sure the connected services have activated fully.
Interestingly, you know this as you've asked the exact same question on an different thread, and even acknowledged the response..
How do you check ? Case of calling the dealer ?
The dealer doesn't know how to get that to work, are you told speed camera ahead or is it just a beep ?
i'm sure ill work it out at some point
thanks 🙂
On 5/18/2022 at 4:33 PM, dee123456 said:
It's just a beep.
This.
2 hours ago, TIL said:
This.
2 hours ago, 50p said:
Oh I quoted the reply saying that the speed camera warning is just a beep.
If you are listening to music / radio the sound dips slightly when the beep alarms you... and on the infotainment if you have the nav map on you will see a small icon showing you the cam / speed and on the road it will start getting closer to you.
