Toyota Aygo x-play dash vibration
Paulmuscat76
Hi peeps
Im quite new to the Toyota world and just purchased a 2019 Aygo the car itself runs lovely but I have noticed a vibration either at low gear or just as I’m pulling away. It’s making the dashboard rattle then as I drive faster it stops. I would just like to know if anyones had this issue or know any fixes?
helpful answers please 🙏
Is it like the sort of judder from the engine running at too-low rpm and about to stall, or like a tyre unbalanced?
Is it shaking the whole car or can you mainly feel it through e.g. the pedals or steering wheel or seat or what?
Moved to the Aygo forum
Does it only do it when cold or warm
I notice it if you slightly push on the accelerator and take your foot off it leaves a judder only for a couple of seconds? It sounding more on the drivers side as if the engine shakes then stops… but like the first you said sounding like it’s going to stall too low rpm
I am still looking for a solution about the judder, but the sound comes from a thick pipe that is attached to the inside of the radiator. It has a bit of a slack and allows the vibrations to create the sound
