Paint Code
Roger F
Hi all, looked at every label I can find but no visible paint code, can anyone point me in the right direction, thank you.
IIRC that should be 089 it's usually on the vin plate or data tag
Yes, it should be on the plate on the door ingo, on mine it says C/TR (colour/trim?)
Oh can’t see anything on the door plate, do you mean where the tyre pressures are.
No, not that one.  On my car the tyre pressure plate is on the drivers side door ingo, but the same place on the passenger side has the vin plate with the paint code.
Thanks will check that out
Like this one. My colour code is 070
Thanks all, found it now.
