red battery light
hammadzzz
hello i got toyota auris 2013 when car go above 60 or 70 red Battery loght come up and car goes to lim mode can anyone help
you can check your owners manual. Red Battery light means your Battery it’s not charging, you should investigate asap or take your car to the dealer.
Different car, different conditions, red light on and remains on.  Switch off all electrics and you may get a few miles to Battery exhaustion and the engine stops.
Best option stop safely where you can.
In the OP case assume the light will stay on and be prepared to stop safely.
Late to the party, but I suspect that the charging system is not good enough. A good auto electrician and diagnostics will confirm what is wrong. As Roy stated above the failure could get worse and permanent.
