Aygo hazard switch
Nigel1967
Hi, new member, this might have been answered somewhere ... should the hazard switch flash in a 2010 Aygo?
Thanks.
I don't think so, they're usually backlit, so you can see them in the dark yes they are a common failure
random pic off the forum
Hazard.jpg.8dfde14415cb3866c16bdb45f0f65
Thanks,  the problem is actually the left turn indicator arrow not working.   That won't be an MOT fail as the 'tick' works but it will fail on the hazards as they should both flash indication, hence my question on the button,  if that should flash then it would be ok ... time to take the binnacle off ...
2 hours ago, flash22 said:
If the indicators work on the car, It's either the power, ground or the led that has died
https://andydoz.blogspot.com/2016/08/citroen-c1-mk-1-peugeot-107-toyota-aygo.html
Thanks, looks perfectly straightforward ... 😉 The £75 that https://www.sancarsauto.com/products/toyota-aygo-instrument-cluster-repair-service?variant=39615287033905 want looks cheap ... Anyone on here ever used these folk or similar?
