Toyota Touch system Bluetooth no audio
mike36
Hi All,
I am having this strange issue with Touch and Go.
This is NSP120 Touch and Go I think its first Gen
I can talk via bluetooth during call.
But for any other audio mp3 or youtube its not playing this audio
tried on iPhone XR
Samsung s10 s20
I am unable to select bluetooth option from menu screen where FM AM CD USB options are
i can make call via bluetooth but as soon as the call disconnected the audio player doesnt work.
It seems i have to upgrade the sw but where
its very frustrating not sure what is happening.
It's the same as the Verso-S it's a very early touch model, does it have sat nav ??
Is this the only hidden menu ??
without "GO" (Navigation):
- Ignition switch to ACC, wait until the radio screen appears (remove CD and USB media)
- Hold down the MEDIA button and switch the parking lights on and off 3 times -> Service Menu
- press "Service Information"
- Press "Program Update"
- connect USB stick (FAT32, min 1GB, with update file, otherwise empty)
- press "OK" (USB stick inserted)
- press "OK" again (recognized, confirm)
- in the now appearing Software version overview "
- Start the update by pressing "OK"
- wait until the blue bar is full and then turns green
- press "OK"
- switch the ACC ignition switch to OFF (leave the USB stick plugged in!)
- turn the ignition switch to ACC (USB stick plugged in leave!), wait until the radio screen appears
- now remove USB stick
- switch ignition switch from ACC to OFF
- wait 30s
- ignition switch to ACC, wait, device should run with new firmware
- done!
Go into the service menu then Function check, what options do you have ??
Go in and check the mic and make sure it works
Yes its working I connected to phone via bluetooth and made call tested as soon as I disconnected the call the bluetooth audio not transfer.
I ran the youtube while on call and can listen youtube but once call disconnected i cant hear anything. it seems audio player is not connected or something else.
So you can't get into the bluetooth menu ?
There are no updates available, the Toyota toolbox was discontinued in 2020 even if you do get the software the servers no longer exist
I can get into bluetooth menu
The issue is i cant play mp3 from phone via bluetooth
Can you pls send me the name of the files that required
There are no updates available. i may have something in my archives
Thanks what I am thinking is to reset it and then reupload firmware.
I think there is a software glitch.
Just looking Fujitsu Ten become Denso Ten if that helps anyone
i am aware of this, i know these systems very well i have repaired many of them, yes its a very early touch system the same as the Verso-s
Thanks much appreciated the swift responses, there is a pdf file which has got links but i am not sure if this can be shared here to help someone.
if you go in to the phone screen and click connect telephone, what icons does it have ?
i can connect from Phone bluetooth to car with no issues. its shows not connected as i am not in the car but i can connect with no issues
The issues is the audio playerimage.thumb.jpeg.df5acfb7dc3b2825e43f168bad74305d.jpeg no sound
Finally Solved it.
In second screen clear the memory and it automatically started the bluetooth after reboot.
I think there is lots of stuff in memory cause this issue cannot solve using soft reset of memory have to be in blue screen menu.
Special Thanks to Flash aka Bob ! I believe he is Kent will meet someday..
  • 11 months later...
Hello @mike36
I have the exact same problem. Can you explain where did you made the memory clear?
Which menu did you used? And how to access this menu?
INIT reset can be done in the hidden menu
let the radio boot, hold the settings button and turn the headlights on and off 3 times
the should give you a menu with a white background, press and hold the INIT button
if you have sat nav you need the other hidden menu
  • 4 weeks later...
Hi
press setup and car same time and 3 times turn on off light
then on bottom right and bottom left screen touch 3 times Left then right left then right  it will pop up
then clear memory
hope that helps
