Rear Shock Absorber Mount bolts
cogstoy
I'm currently changing the lower suspension arms on my 2003 T25 Avensis, I had to cut the rear shock absorber mounting bolts to get it off and now need two bolts to replace, does anyone know of a place online I can get them?. I've check motor factor and done online searchs but no good. Any help appreciated, thanks.
Looks like they are Toyota part only, Toyota wouldn't release then for motorfactors to sell. Bummer.
You can check local dealer, they might not be very expensive. I found online Lexus parts at £20 per bolt. https://lexuspartsdirect.co.uk/product/lexus-ls-phase-2-rear-axle-carrier-bolt/
https://japancars.ru/index.php?route=catalog/toyota&mdf_id=1580&area=EU&cat=273550&blk_id=4804
part number 90119-14025
