Aygo MK1 2012 5-door RHD Door Removal
Pam the CityBug
I need to replace the right hand front door on my Aygo MK1 2012 5-door UK RHD. I know the wiring loom from the door is connected via a plug that passes through the A-pillar but do I access that connector from the footwell, from underneath or from behind the scuttle?
Connectors are located behind the lower kick panel by the driver's foot
click to enlarge
I see those now. Loom labelled 24.
Thanks. I know it seems easy to investigate, but on an older car, when the plastic has hardened, it can sometimes result in unnecessary broken tabs. I know this from my older Nissan 🙁
Toyota doesn't seem too bad, Nissan clips snap if you look at them wrong even at 3-4 years old
