Avensis Alloy Wheels
Graeme
I have a 1.8 Avensis SE 1999 hatchback and have minor damaged the outer rim of one of the alloys in a pothole and at the same time punctured the tyre.
Is it possible to get a repair done on an alloy?
Where can I obtain the type and number of the alloy for reordering purposes if this is necessary and can this be done independently rather than through Toyota.
In the inner part of the alloy is stamped UGER 6 1/2 x 15 H2. Tyre size is 195/60 R15 88H.
Can anyone help?
To reorder a toyota alloy wheel you will need to get it through your maindealer and your maindealer will be able to give you a part number once they see what type it is. You could get it refurbed but the knock you have described it sounds like it is warped so would be cheaper to get a new one :thumbsup:
