2016 Avensis Front Fog bulp replacement
musicman100
Has any one found a video or instructions to do this?
All I have found is this
he job of changing the front foglight on a T27 avensis is quite easy and only needs part of the inner wing liner losening, and not the whole of the front bumper as perviuosly suggested.
Once the inner wing liner has been lossened it just needs a phillips screwdriver to change the unit. it took me about 30 mins to do from start to finish.
Jinks
How do you loosen the inner wing liner?
