Aygo 2014 radio upgrade **Help**
cowboyonrails
Hi
We have bought our daughter her first car which is a 2014 Toyota Aygo has the attached radio fitted, we are wanting to upgrade it for her to a radio which is compatible with Apple car play and preferable with a large screen fitted for satnav. We have tried searching youtube for ideas but struggling, has anyone done this and any tips on systems or places to purchase from.
Thanks for any help.
3 minutes ago, flash22 said:
What is your budget ? Do not buy, no name Chinese tat
We are probably looking at no more than £400 to £500 if possible, yeah trying to avoid using the Chinese tat 🙂
As it's an early Mk2, fitting an oem tripleplay unit may require some wiring (86140-YY020) you will also need a dab aerial
Aftermarket - Pioneer SPH-DA160DAB you will need a fascia adapter, wiring adapter, Aerial Adapter and a DAB aerial - you can add a reverse camera if you desire
Thank you will start looking around for the required parts and start stripping the old system out.
Facia to fit an aftermarket double din - Connects 2 CT23TY51
That's fantastic thank you, I really appreciate your help
