venomx Posted September 7, 2022 Share Posted September 7, 2022 Few weeks back when driving it feels as if my foot is being tapped very lightly when using the pedal at times. MK2 Yaris. Pedal doesn't have any play in it whatsoever and feels to be secure, no problems accelerating either. However if I turn the engine off and press the pedal with my hand forward and backwards, it feels as if it doesn't move as smoothly as before, it doesn't stick or anything like that. Is this just wear and tear or is it possible I can a tiny bit of some thick silicone grease on the mechanism to help keep it lubricated ? Quote Link to comment Share on other sites More sharing options...
TonyHSD Posted September 7, 2022 Share Posted September 7, 2022 Well everything possible. You can try lube where the bearing point if it’s cable operated , if drive by wire then will be closed in plastic box and no point touching it. 👌 2 1 Quote Link to comment Share on other sites More sharing options...
venomx Posted September 9, 2022 Author Share Posted September 9, 2022 On 9/7/2022 at 9:09 AM, TonyHSD said: Well everything possible. You can try lube where the bearing point if it’s cable operated , if drive by wire then will be closed in plastic box and no point touching it. 👌 Yeah there is a small plastic box so probably have to live with it. Tried a tiny bit of thick lubricant on the outside where there is some contact but no luck. 1 Quote Link to comment Share on other sites More sharing options...
corradovr6 Posted September 9, 2022 Share Posted September 9, 2022 Check the other end of the cable on the throttle body and see that it doesn't stick there and that the throttle body opens and closes cleanly 1 Quote Link to comment Share on other sites More sharing options...
venomx Posted September 9, 2022 Author Share Posted September 9, 2022 32 minutes ago, corradovr6 said: Check the other end of the cable on the throttle body and see that it doesn't stick there and that the throttle body opens and closes cleanly I'm not that experienced with cars but I'll try to have a look. Googling bad throttle body symptoms I don't have any of them. I'm fairly sure mine is electric as the pedal seems to attach to a few cables. I'll take a picture tomorrow Also, I feel the sensation even with the engine off and keys out of the ignition so surely that rules out the throttle body? Quote Link to comment Share on other sites More sharing options...
Big_D Posted September 9, 2022 Share Posted September 9, 2022 I'm not sure if it is electronic, or cable operated. If it's cable, it may need to have some lube put back in between the sheath and the cable. A cable oiler will work for this I suspect it's electronic, as with most newer cars. In this case, it may need a clean with some switch cleaning spray. Quote Link to comment Share on other sites More sharing options...
corradovr6 Posted September 9, 2022 Share Posted September 9, 2022 Sorry Terry, i was assuming yours was a Mk1 yaris, like mine 1 Quote Link to comment Share on other sites More sharing options...
Derek.w Posted September 9, 2022 Share Posted September 9, 2022 Mk 1 or Mk2 Yaris I lubricate the pedal linkages the the throttle itself then disconect the cable and check that for smooth mechanical movment of inner cable. Quote Link to comment Share on other sites More sharing options...
venomx Posted September 10, 2022 Author Share Posted September 10, 2022 As Tony said probably nothing I can do. This is the mechanism, it's entirely electrical. Quote Link to comment Share on other sites More sharing options...
Big_D Posted September 11, 2022 Share Posted September 11, 2022 As it's electrical, it could be cleaned by spraying and electrical switch/contact cleaner spray inside the unit. I did this years ago with a Ford I had and it cured the problem. The had part was getting the spray inside the unit. Usually there are small openings in the housing where you can get the spray nozzle into. 1 Quote Link to comment Share on other sites More sharing options...
TonyHSD Posted September 11, 2022 Share Posted September 11, 2022 19 hours ago, venomx said: As Tony said probably nothing I can do. This is the mechanism, it's entirely electrical. You can take the pedal off the car, watch this video and see what’s inside, check if you can open it and clean and re apply grease ( contact dielectric grease, silicone one only) then out all back together. The issue you have is most likely dried grease on the contact lines or plastic bearing point. Is it worth trying, it’s up to you, there is always a small risk doing something wrong and you will need to replace the pedal. You decide. 👍 1 Quote Link to comment Share on other sites More sharing options...
venomx Posted September 11, 2022 Author Share Posted September 11, 2022 6 hours ago, Big_D said: As it's electrical, it could be cleaned by spraying and electrical switch/contact cleaner spray inside the unit. I did this years ago with a Ford I had and it cured the problem. The had part was getting the spray inside the unit. Usually there are small openings in the housing where you can get the spray nozzle into. What was the issue with your Ford ? Similar thing ? I'd assume electric contact cleaner is safe to use ? I'd rather not risk it as I'm not experienced and don't like the idea of liquids near important electrical components. I'll try some more thick lubricant but after that I will leave it alone, don't want to take any chances just for a minor issue Quote Link to comment Share on other sites More sharing options...
flash22 Posted September 11, 2022 Share Posted September 11, 2022 Leave well alone, what you are feeling is the wear spot (years of use only in certain throttle positions) the carbon tracks will start to break down, and you end up with a dead spot or no throttle change the pedal (complete assembly) you need the correct type of lube for inside the switch that is non-conductive, and non-solvent based cleaner - you will kill the carbon tracks with the wrong type Cost wise, just replace the pedal 1 Quote Link to comment Share on other sites More sharing options...
Derek.w Posted September 11, 2022 Share Posted September 11, 2022 Other than a drop of oil on the plunger its a replacment component. Quote Link to comment Share on other sites More sharing options...
venomx Posted September 12, 2022 Author Share Posted September 12, 2022 13 hours ago, flash22 said: Leave well alone, what you are feeling is the wear spot (years of use only in certain throttle positions) the carbon tracks will start to break down, and you end up with a dead spot or no throttle change the pedal (complete assembly) you need the correct type of lube for inside the switch that is non-conductive, and non-solvent based cleaner - you will kill the carbon tracks with the wrong type Cost wise, just replace the pedal So I need to get it replaced ASAP? I've looked around and cannot see any new ones for the Yaris MK2. MOT soon so I'll get them to look Quote Link to comment Share on other sites More sharing options...
venomx Posted September 12, 2022 Author Share Posted September 12, 2022 The 08 Yaris is listed here on a recall list... https://en.wikipedia.org/wiki/2009–2011_Toyota_vehicle_recalls#Accelerator_pedal_recall https://www.drive.com.au/news/toyotas-sticking-accelerator-recall-remedy/ However when I go on the Govt MOT website, enter my details, it says " no safety recalls found " the car was purchased from Toyota used approved in 2018 Quote Link to comment Share on other sites More sharing options...
venomx Posted September 13, 2022 Author Share Posted September 13, 2022 What a plonker. The pedal had a tiny bit of grease on it. Cleaned it off thoroughly now it's fine 🤦♂️ 3 2 Quote Link to comment Share on other sites More sharing options...
Derek.w Posted September 13, 2022 Share Posted September 13, 2022 Glad you sorted it out. 1 Quote Link to comment Share on other sites More sharing options...
Big_D Posted September 13, 2022 Share Posted September 13, 2022 At least you got there in the end 😀 1 Quote Link to comment Share on other sites More sharing options...
Toyota Official Store
Sponsored Ad
Toyota Model: Toyota Store
Toyota Year: 2024
