Catalytic Converter Lock from Toyota is it worth getting it fitted to Hybrid?
Bruce Lea
45 minutes ago, Bruce Lea said:
You mean turn the front wheels so they point straight to the the kerb?
What reg is your car, that shape auris is solid hybrid, nice car
Not the wheels the whole car to be close to the kerb or when in car parks front end close to wall so they have no or limited access to the jacking points to lift up. Lifting from rear will not suit them . My car is same as the blue one from picture 2010 model
Ok, front end close to wall in car parks is not possible? Not seen car parks with a walk where you can park right upto it?
What about parking on the road or street? Turn the wheels towards the kerb?
The wheels position doesn’t make any difference imo. But don’t worry too much about it. If it’s about to happen it will if not it won’t. No need to stress.
I will definitely install catalytic Lock in every car I have in UK probably since 2 years ago.
