SR180 dpf pressure sensor.
Weary
Hello all. Not sure if you can help, but my Auris went on to limp mode - on the M25!! - and the AA said it was the regen pressure/temperature sensor. I think it's only regenerated once in the 18 months that I've had it, which doesn't seem right considering that I mostly do town driving.
Has anyone had experience of this? Do you know where is best to get parts? (My mechanic reckons we should start with the pressure sensor 8948012020, as he's had no joy trying to get it to regen)
Any advice would be greatly received.
Thanks in advance,
Paul.
It might be worth trying to find a DPF specialist in your area as they'd be able to diagnose it better. Because DPFs cause so many problems there are more specialist places around these days.
These guys are affiliated with the simplydiagnostics people on youtube, may be more reputable...?
https://www.the-dpf-doctor.com/
Good idea. I've found a DPF Doctor fairly near to me. If the new sensor doesn't do the trick then that will probably be my next port of call.
